Re: W4 rear tire rims
Posted by Red Mercury on July 27, 2013 at 12:42:48 from (204.112.60.119):
In Reply to: Re: W4 rear tire rims posted by rustred on July 27, 2013 at 09:52:09:
Yes, the early W-4's had split rims. I have the same problem with a 1941 W-4. One rim is a one piece rim and the other one is a split rim. Different sized tires too if I remember correctly. Basically a PO found a deal on a used tire with rim from a newer tractor. The other split rim wheel ended up in someone's junk pile. Too bad, I would like to have the other split rim for it.
