Re: Generator Output
Posted by El Toro on July 27, 2013 at 13:08:32 from (108.3.218.181):
In Reply to: Generator Output posted by gtwist on July 27, 2013 at 12:48:15:
If your generator is on your tractor you can check the charging voltage across the battery terminals with the engine at 1/2 throttle or better. Set your meter on DC volts. Should see
about 7 volts on a 6 volt battery and 14 volts on a 12 volt battery. Hal
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
