You have a -so called- one wire alternator. It is likely causing the issue. The image here will do the trick when installing a much more controlled alternator. Delco 10SI 3 wire. If you do not want to use an amp gauge, just use the same hookup for the alt big wire to the starter terminal going to the battery. I recommend the fuse link to avoid melt down of wiring. The mention of a mag is because this wiring will also work for a mag or diesel. (neither need elecrticity to run. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
