Re: Generator to alternator (1256)
Posted by karl f on July 27, 2013 at 20:02:49 from (172.129.32.74):
In Reply to: Generator to alternator (1256) posted by jeddie on July 27, 2013 at 15:47:35:
Also if your 1256 still has 2 batteries (6 volt in series to make 12 volts), if one battery is boiling and the other is not, your problem is a cable connection between the batteries, or the battery cover might be shorting the wrong post to ground. Also the batteries could be connected wrong and be operating at only 6 volts (I don't think it would start!) You might even have 2 12 volts hooked up wrong (24volts!), since anything can happen in 40 some years with untold numbers of hands messing with it.
karl f
It's very tempting to switch to one group 31 (12 volt) battery on these tractors, even though it isn't factory correct
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
