This 756 tractor has left hyd connectors out the back and steel tubing going forward on both sides of the seat. The left rear tubing is a one piece setup with both tubes going backward into a solid block that looks like a check valve (but isn't). Then the left front tubing connects to this block on the side and goes forward along the seat.
I understand what you are saying about the right valve connecting to the port side into the casting then out the back. It makes more sense than trying to use the same pipes to connect the second valve to the port side. Once the first valve is plumbed in, it will operate two more rear remotes and it also connects to the right front hyd outlets. I have picts of the connections on a 706 that uses tubes as you describe (I have those) but uses two seperate tubes from the left valve out the rear. Some tractors have hyd tubes or hoses exiting out the front of the seat platform that come up under or near the center steering column.
I'm hoping an Farmall expert will chime in, that is farmilar with the one piece steel tube setup with both valve connection tubes exiting out the back into a solid block that then hyd connectors can be mounted. I need to know if this is modified to fit?
Thanks for your help, You've answered part of my questions, Loren
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
[More Ads]
