Posted by John T on July 28, 2013 at 05:30:56 from (216.249.76.176):
In Reply to: Generator Output posted by gtwist on July 27, 2013 at 12:48:15:
Jim was already kind enough to post the link to my Troubleshooting Procedure and Hal has ya covered as well, so FYI an even sipmpler check is to turn the lights on and see if they get brighter from a slow idle to wide open throttle??? If they brighten up noticeably as the RPM goes up its likely charging. The gennys output is between its ARM post and case/frame ground, but an open unloaded voltage test there doesnt tell you as much as to what voltage it can raise the batttery as Hal pointed out.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
