Re: Using Aceatone and ATF
Posted by MNGB on July 28, 2013 at 05:57:22 from (67.230.225.74):
In Reply to: Using Aceatone and ATF posted by James Williams on July 28, 2013 at 05:23:52:
There is no acid in either product acetone is thinner similar to lacquer thinner and of course ATF is automatic tran fluid, so go for it I use it all the time to clean carbs and other parts works very good.
GB in MN
