starter problem on 300U
Posted by charlie M on July 28, 2013 at 07:17:19 from (184.8.85.210):
The starter on my 300U has started making a grinding type sound often when I try to start it. If I hit the switch several times it will eventually engage and turn the engine. Its not a problem with the ring gear as I know that problem. Can it be the drive unit on the starter that is a problem. Its a 12V system and cranks fine when it finally does crank.
