Re: 1947 Farmall A - removing rear wheels
Posted by charlie M on July 28, 2013 at 08:43:46 from (184.8.85.210):
In Reply to: 1947 Farmall A - removing rear wheels posted by Mark Slavens on July 28, 2013 at 08:32:05:
If you still have the rear end attached to the front end you have to be careful when you remove the rear wheels as the tractor is weighted to one side and it will tip that direction if given a chance. When I did mine to change seals I jacked up one side at a time and sat it on cement blocks. I reassembled that side before going to the other side.Probably lots of better ways to do it.
