Support placed inder the mating surface of the drive housings after the pans have been removed is very effective in several ways. It is wide enough to prevent tipping. It is sturdy. If bolts are put into the housing with the pan off, the bolt heads will provide a protection for the surface. DO NOT. use concrete blocks. They are good only if the full upper and lower surfaces are in force contact with the floor or lifted object, They shatter and near explode with point loading. It is just not worth the risk. (I lost a friend to concrete blocks) Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
