Re: Re: Re: 12 Volt on M
Posted by Bob M - sure... on November 27, 2000 at 04:49:58 from (192.232.120.194):
In Reply to: Re: Re: 12 Volt on M posted by Country Boy on November 26, 2000 at 20:20:38:
The alternator setup will work find on an MD. You'll need to swap the battery connections to make the tractor negative ground, then swap the connections at the ammeter so it reads correctly. Also if your MD's are equipped with magnetos, you'll need to provide an on-off switch in the line to the alternator warning light since there is no "ignition" switch to control the alternator.
Post A Followup
: Re: Re: Re: Re: 12 Volt on M
