Re: 656 TA/clutch housing install issues
Posted by pete 23 on July 28, 2013 at 19:41:27 from (74.47.41.165):
In Reply to: 656 TA/clutch housing install issues posted by Kevin NE Ohio on July 28, 2013 at 17:50:39:
Sounds like you damaged the pressure plate when you bolted her together. We normally hang the clutch on transmission shaft and bolt to flywheel from underneath to avoid this problem. Far as neutral, a 656 is also difficult to assemble ta section to rear because you cannot visual the pilot bearing. I always put a rubber band on the pilot bearing, put transmission in 4th gear to support front of main shaft and peek in with a mirror to make sure all is going together properly. I would jack up rear wheel and play around with the shift linkage to make sure problem is external or internal.
