Re: 656 TA/clutch housing install issues
Posted by Kevin NE Ohio on July 29, 2013 at 05:14:41 from (70.194.214.19):
In Reply to: 656 TA/clutch housing install issues posted by Kevin NE Ohio on July 28, 2013 at 17:50:39:
Is there a way to tell if the pressure plate is damaged? Also if the rear pilot bearing is not properly seated it will cause it not to go into neutral?
