Re: M&W hand clutch
Posted by kevinj54 on July 29, 2013 at 05:38:05 from (162.17.149.81):
In Reply to: M&W hand clutch posted by mkirsch on July 29, 2013 at 05:27:44:
Did you pry out the lock tab?
Nut should turn easy if the tab is out and the clutch is open.
You won't turn it if the clutch is closed.
