Re: M&W hand clutch
Posted by DeltaRed on July 29, 2013 at 07:29:54 from (97.118.26.184):
In Reply to: M&W hand clutch posted by mkirsch on July 29, 2013 at 05:27:44:
It should move easily once the lock tab is moved.A
light tap and a pair pliars will easily turn the
nut.Never heard of a special wrench/spanner for
one.Make one.Take a socket of correct size and grind
4 'pins' into it to fit the nut.There is nothing to
bind up...Is there rust?Is the nut/shaft 'galled'?If
you ruin the nut,I may have an extra one.In fact,I
have an almost comlete clutch for an M on the shelf
