Set #3 at 3 full turns out and leave it there. You ABSOLUTELY will not notice any difference in how the tractor runs UNLESS the engine is wide open under FULL load. If the engine sputters and stumbles under full load, then open the #3 screw in 1/2 turn increments until it smooths out. If the tractor is doing ONLY light work, such as tractor rides or parade duty, then the #3 screw can probably be turned IN to 1 1/2 to 2 turns out for better fuel efficiency.
Try to understand the "load adjustment" screw. It provides a way to adjust the amount of fuel the engine receives in order to realize the greatest fuel effiency under varying WORK LOADS.
The factory initial setting IS 3 turns out.
For what it's worth, that carburetor in the picture is for an M. It is NOT a Super M carburetor, but will work equally well. A Super M carburetor will have the choke lever on the INSIDE.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
