Yes indeed, the VR needs a good frame ground to complete the regulated field current circuit plus operate the shunt winding portion of the Cutout Relay.
Check that frame ground connection and have the junctions clean n shiny bright.
However, I guess there could also be a short causing the problem as the VR"s BAT terminal has hot battery voltage going inside to the Cutout Relay. Such a short might draw higher curent then those noted above!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
