Re: M hydraulic problems could use some experience here
Posted by D Slater on July 29, 2013 at 16:29:46 from (184.14.183.16):
In Reply to: Re: M hydraulic problems could use some experience here posted by NolanJae on July 29, 2013 at 12:52:51:
Did you put oil in the transmission or in where the cap is with the bleeder? That's a original liftall reservoir that originally was driven from the transmission counter shaft. Drain plug is near the filter. With the add on hydraulics they made changes to the system. If you didn't put oil in the hydraulic reservoir that may be the problem.
Holds about 6 quarts if empty, maybe 2 gallon if all the original internals were removed.
They made one set up that put pressure to the original hydraulic valves through the original drive shaft hole. If that's where the one pipe is going up inside the housing things are plumbed wrong. If the line goes in lower down that's probably okay.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
