Re: 1466 aux hyd valve under seat???
Posted by Larry B. 1486 on July 29, 2013 at 17:33:31 from (98.19.163.140):
In Reply to: Re: 1466 aux hyd valve under seat??? posted by pete 23 on July 29, 2013 at 11:22:56:
Thanks pete 23. It's not the linkage. I screw the spool out the back today and still have it out. I can push it into the threaded pipe end but will not pull out. I have taken spools out before to replace O ring but have no ideal how to fix this problem. If you get back to this post and can give me some direction on what to do it will be appreciated. Larry
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
