Re: F 20 exhaust pipe and muffler
Posted by robgIN on July 29, 2013 at 18:14:54 from (70.224.35.108):
In Reply to: F 20 exhaust pipe and muffler posted by SDE on July 29, 2013 at 16:50:22:
what manifold do you have ? the Heisler gas manifold has a pipe that screws in to the manifold that probably has rusted off too short. If so you can replace that pipe with a longer one. If you have an IH gas manifold they have a "chimney" that bolts on to the manifold with 3 bolts and should stick up above the hood enough to put a muffler or elbow on without hitting the hood, those chimneys are available from several sources.
