Re: Super M carb adjustment(double checking here!!! :(
Posted by GordoSD on July 29, 2013 at 19:22:49 from (216.106.247.186):
In Reply to: Super M carb adjustment(double checking here!!! :( posted by mike1972chev on July 29, 2013 at 07:49:57:
You won't see or hear any change in the rpm of the engine when changing the load screw at idle . It is not an idle jet. As others said you have to apply the throttle or go work it to adjust that. Hook up your plow or cultivator and make some adjustments. If you don't see changes there the carb is *********
