Re: 656 TA/clutch housing install issues
Posted by Owen Aaland on July 29, 2013 at 20:55:41 from (216.47.34.58):
In Reply to: 656 TA/clutch housing install issues posted by Kevin NE Ohio on July 28, 2013 at 17:50:39:
If the levers are too far forward you may have the clutch disk in backwards.
