Re: Super A hydraulic update.
Posted by Dennis K (WA) on July 30, 2013 at 07:41:09 from (24.21.78.195):
In Reply to: Super A hydraulic update. posted by chad from michigan on July 30, 2013 at 03:30:58:
Good morning Chad,
It is not a lack of oil or the loader would not go all the way up empty. You are lacking pressure because of the relief setting on the loader valve. Either the loader valve relief has a problem, the setting is too low or the pump cannot develop enough pressure because it is worn out.
The loader quits going up loaded early because the leverage changes at the cylinder as it extends.
You need to find out what max pressure the loader should have and get a gauge that goes high enough to handle it.
If the spec pressure cannot be obtained, you need to find out why.
Matt is right, pressure readings are relative to resistance.
Remember, flow is speed or movement and pressure is power.
You are lacking power.
Good luck with it
Dennis
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
