In the grand scheme of things it probably doesn't matter.
SAE-30 non-detergent is just straight up oil with no additives, so if a little gets in the Hytran, or a little Hytran gets into it, there won't be any adverse reactions.
The problem I have is finding non-detergent oils. There's pallets of hytran or hytran-compatible oil in every farm store, but only once in a while do I ever see a few quarts of non-detergent motor oil on the shelves.
What is the point of running around town paying too much and dealing with tiny quart jugs of non-detergent motor oil when I can just pick up a 5-gallon pail of hytran compatible stuff at the first store I go into?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
