350U hy. pump
Posted by FLOLDFORD on July 30, 2013 at 16:00:49 from (65.33.89.5):
I have a 350 gas utility that the hydraulic pump is getting weak on and starting to leak out of the tach drive. The cost of a rebuilt pump is pretty high at around $800. Would it be feasible to just mount a crank driven pump on the front and not use the original pump just let it stay there to drive the distributor. I have a new 7.5 gpm pump in the shop and I could cut and tig weld fittings to the existing hard lines to run hoses to the new pump. Is it worth the trouble or should I just bite the bullet and buy a new pump
