Re: ignition problems IH 450 12 volt
Posted by SDE on July 30, 2013 at 16:25:17 from (174.124.43.71):
In Reply to: ignition problems IH 450 12 volt posted by tom levandoski on July 30, 2013 at 15:51:16:
First you should check the battery terminal connects. Clean them and re-tighten the clamps. Both ends of both cables.
SDE
