Re: M&W hand clutch
Posted by kevinj54 on July 30, 2013 at 16:55:05 from (50.42.187.103):
In Reply to: M&W hand clutch posted by mkirsch on July 30, 2013 at 13:15:02:
Mine has parts drawings for h, super h, m, super m, w series in the back
I might have a super manual somewhere.
The clutch pack itself is the same for an m or a super.
Not much inside there, just a cam clutch
You probably need the outer bearing, oil seals, and a good cleaning and lube job and will work fine.
I put up a pic of the clutch pack, it just slides out of there.
