Re: Super C hyd. pump
Posted by Rick Remmert on July 30, 2013 at 17:41:57 from (68.103.4.23):
In Reply to: Super C hyd. pump posted by mtn.man on July 29, 2013 at 19:10:10:
A word to the wise. Be careful with item #13. It is a square cross section o-ring. As far as I could find, they are no longer made. The rest of the o-rings can be matched up at a supply house. The seal I got at NAPA, but I can't find the part number for you. I just took the old one in and he matched it up. The new style seals are now much thinner than the old ones. You just need to measure where to put it so it does not run on the old seal grooves in the shaft. If I remember right, I put mine in as far as it would go.
