Re: broken 9 bolt hub
Posted by The tractor vet on July 30, 2013 at 18:51:20 from (75.19.124.38):
In Reply to: broken 9 bolt hub posted by farmalllh on July 30, 2013 at 13:24:45:
Depends if it is cast steel or cast iron . Cast steel can be welded and SHOULD be ok Cast iron can be welded but as far as strength ??? i would not trust it on hub . Yes i can weld and weld well good enough to do high pressure welds and at one time had the certificate . To even get close to the org. strength you will have to PRE heat and hold the heat while welding then it must cool vary slowly over time . and MOST people can not do this . It may be easier to just get a used hub and start over . And this time use a torque wrench .
