Not to hard, under the pump mark how the slot is positioned before removing it if needed to install back the same. Put a screwdriver or something in the drive slot to twist back and forth for the backlash using a dial indicator if you have. The gear and shaft passes through a adapter that is oval shaped to change the backlash. Has different holes you can spin it to. Oil seal is under the adapter. Been so long ago that I can't remember if the shaft has a o ring or seal on it also. Anyway the slotted shaft with gear and adapter will pull out and you can see what's needed. Just don't turn the engine and put the slot back the same direction. Think I remember a dimple or mark on one end of the slot. Not sure of my memory though. Last one I did everything was worn so much it took all the adapter would give to get the backlash to .006 I think it was.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
