Re: ignition problems IH 450 12 volt
Posted by Janicholson on July 30, 2013 at 20:29:24 from (74.60.94.18):
In Reply to: ignition problems IH 450 12 volt posted by tom levandoski on July 30, 2013 at 15:51:16:
Use a jumper cable as a connection paralleling the lead to the starter switch. If it then starts, the issue is the cable. Many times the cable is internally corroded. It should also be possible to find a hot connection or warm wire if a connection is bad.
Hook a test light to the connection going into the side of the starter. If it lights when the key is turned to start, the issue might be in the starter.
Jim
