Re: broken 9 bolt hub
Posted by Janicholson on July 30, 2013 at 20:59:37 from (74.60.94.18):
In Reply to: broken 9 bolt hub posted by farmalllh on July 30, 2013 at 13:24:45:
If it is a working tractor Imagine what the effect would be if it broke while moving. Not a good idea. Were it mine I would replace it. Make sure the shaft and hub are smooth and clean before assembly. A single bit of dirt or paint can creat point loading on tightening that will break them every time. Jim
