Re: Farmall A Magneto skips time
Posted by El Toro on July 31, 2013 at 06:31:07 from (108.3.218.181):
In Reply to: Farmall A Magneto skips time posted by ccaissie on July 31, 2013 at 06:22:16:
When it quits again bring No1 piston near the radiator to tdc on the compression stroke. Then remove the cap and see where your rotor is pointing. If it isn't pointing to the No1 plug wire your drive gear on your mag may have sheared the woodruff key or on the cam gear. Hal
