For it to slip EXACTLY one position in the distributor cap is suspicious. It is practically impossible for that to happen in the real world without human intervention.
If this has only happened once, then odds are the farmer pulled the wires to troubleshoot, and put them back wrong.
Multiple times, someone is playing tricks on you.
The timing just does not slip exactly one position.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
