Are you sure the rotor isnt worn and does not lock on the shaft like its supposed to. The rest of the stuff in the mag are bullet proof and dont slip. If there are teethe gone from the cam or gov gear that would let it jump out of time. You say you move the wires and it starts that would almost make the gears on the gov and cam the culprit you can remove the gov assy then you will be able to check those gears for missing teeth. When everything is lined up #1 position on the mags rotor will be lined up at approx 1 oclock position where the base of the coil sets in line. I would pull the gov assy off to check for missing teeth on either the gov gear or the cam gear or maybe some are gone from both.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
