Re: wide front end
Posted by mkirsch on July 31, 2013 at 07:40:12 from (64.80.110.74):
In Reply to: wide front end posted by butch49 on July 30, 2013 at 22:01:10:
There should be plenty of room between the fan and the radiator to remove the belt. No need to remove the radiator.
Something is off on your tractor.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
