Posted by farmerhr on July 31, 2013 at 19:49:08 from (108.224.0.124):
In Reply to: wide front end posted by butch49 on July 30, 2013 at 22:01:10:
I added a wide front end to my Super M several years ago. Two inch and a half holes were drilled under the bolts that hold the radiator on so that the radiator could be removed without removing the front end. I have used the holes once to remove the radiator and was sure glad they were there. By the way, a hole saw was used to make the holes and they worked well. Hope this helps. Many Thanks !
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
