Re: M&W hand clutch
Posted by kevinj54 on August 01, 2013 at 13:54:30 from (50.105.83.20):
In Reply to: M&W hand clutch posted by mkirsch on August 01, 2013 at 10:34:33:
Nut is bottomed out then, time for a rebuild if you can get that nut off.
Still may be best to pull the pack out to work on it, you may need a new seal on the pinion and behind the brake drum, there are also 2 bearings in the cam that need checked and greased.
Bearings, nut, locks, disks are all available. I have some parts in stock.
