Re: H Clutch Update Question
Posted by rhtx55 on August 01, 2013 at 19:27:49 from (68.185.207.25):
In Reply to: H Clutch Update Question posted by FBH44 on August 01, 2013 at 17:13:58:
It may be possible the clutch rod ( holding by one thread) is from another tractor, measure the length.
1. Check clutch release fork (over the throw out bearing) it's either bent, or not tight on the clutch shaft.
2. Check keyways on both sides of clutch release fork that are in the shaft for slop.
3. Check the clutch release "pins" on both sides that engage slots in clutch release fork for excessive wear.
You are getting some serious slop somewhere, I would almost bet the release fork is loose on the shaft.
