Re: H Clutch Update Question
Posted by Owen Aaland on August 01, 2013 at 22:28:39 from (216.47.32.215):
In Reply to: H Clutch Update Question posted by FBH44 on August 01, 2013 at 17:13:58:
Before you check the lever height of 2 5/32" you have to make sure the cover height is held to 27/32". That is why adjusting the lever height with the clutch installed is just a guess.
At this point, since you have already disturbed the lever adjustment, I would just adjust the levers until they are parallel with the flywheel and make sure the release bearing contacts all three levers simultaneously. If you want the adjustment threaded in more than that, move the lever height a little more to the rear.
