Re: H Clutch Update Question
Posted by Owen Aaland on August 02, 2013 at 03:20:43 from (216.47.32.215):
In Reply to: H Clutch Update Question posted by FBH44 on August 01, 2013 at 17:13:58:
As long as you are going to take it apart again you should check to make sure the step in the flywheel is 1.188".
