Re: Farmall Cub - Gas Tank
Posted by Dan Richardson on August 02, 2013 at 03:49:07 from (67.236.5.57):
In Reply to: Re: Farmall Cub - Gas Tank posted by anvilheadtexas on August 01, 2013 at 16:27:45:
If your tank is rusted as bad as you say no cleaning will do a complete job unless you open the tank. Use a sawzall and cut around the seam. Then clean it and make the repairs from the inside. When it it welded back together then coat the inside.
