Re: 674 International Tractor
Posted by Peter123 on August 02, 2013 at 04:54:47 from (195.228.173.89):
In Reply to: 674 International Tractor posted by nshawkins on August 01, 2013 at 15:02:25:
When I have had fuel problems on my 454s I have found that having a full tank helps get fuel through, so much so that, for instance, I would not dream of changing the fuel filter without filling the tank to the brim. Also check that the tank outlet is not partially blocked by removing the tap and checking for a healthy flow, or disconnect the input pipe to the fuel filter and check there.
