Many times the front stub of the drive shaft will hang up in the pilot bushing in the flywheel requiring lubrication. Tape a couple of spray straws together and reach them in through the hand hole in the bottom of the torque tube to the front of the shaft. Spray your favorite penetrant or lube. Sometimes helps to have the tractor parked on a downhill slope so it runs down the shaft. To test for this try starting the tractor in gear with the clutch pedal pushed in. Also often helps if the pto is in gear to increase drag on the driveline.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
