Posted by Brady Miller on August 02, 2013 at 12:56:37 from (166.137.119.27):
Gentlemen,
I am restoring a farmall m early serial #. The question I had was the left side shaft housing from the differential to the brake drum has about 10-13 thousands gap between the bearing and the differential, do I need to make sure to close that gap to insure proper ring gear/pinion gear operation? Also, I have about a 1/4 inch play (laterally) in the shaft on the left side that runs from the differential to the brake drum, will tightening the brake drum on the outside hold the double splined shaft in place?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
