Hi Rod, remove the inspection plate on bottom of clutch housing and check for metal bits. It is difficult to see much as the clutch release bearing is in the way. The clutch release bearing can be moved rearward by removing the pin in the clevis connected to the clutch foot pedal. The PTO shaft is the outer shaft and it goes into splines in the clutch pressure plate. The splines on the pressure plate or the splines on the PTO shaft can wear out and strip giving metal bits in bottom of clutch housing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
