Posted by gene bender on August 02, 2013 at 18:25:12 from (67.55.226.10):
In Reply to: 140 governor posted by farmall4856 on August 02, 2013 at 17:24:17:
You dont adjust the gov but you do adjust the linkage going to the carb. With engine off remove the pin in the clevis now open throttle and adjust the clevis so th pin goes in hold the carb open. If the input shaft wobbles a bushing can be installed so that shaft just moves back and forth. Are the springs loose on the throttle rod that connects to that shaft sometimes they are coated with paint and or rust. Is the spring in the gov good.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
