Re: Question about F12 fuel tank
Posted by Tom Fleming on August 03, 2013 at 02:01:36 from (67.20.233.75):
In Reply to: Question about F12 fuel tank posted by arkfisher on August 02, 2013 at 15:31:55:
well, one of the things you should also do is give the tank a good soak/rinse with acetone. Muriatic acid will dissolve and take care of rust, but it won't touch varnish or hardened fuel. Acetone will dissolve and remove a good bit of that.
Epoxy cures (hardens) in 2-3 hours depending upon temp. I use Caswell, but as I said, Red Kote seems to be one of the better solvent based ones out there. I personally have never used it, but that doesn't mean it's not a good product.
