Re: F-20 backfire
Posted by Tom Fleming on August 03, 2013 at 02:07:11 from (67.20.233.75):
In Reply to: F-20 backfire posted by EM Iowa on August 02, 2013 at 20:26:55:
yup, I agree, sounds like your timing is a wee bit advanced, which is not cool for cranking for sure. Yup, under load, the advanced timing makes her purrrrrrrrrr. My suggestion is to set it as the manual says, and it should be TDC when the impulse trips. set it that way.
