Posted by Janicholson on August 03, 2013 at 07:25:36 from (74.60.94.18):
In Reply to: 46 H Drum Brakes posted by LJW on August 02, 2013 at 18:38:24:
I agree with Owen, to check it, look for color differences and glazing of the friction surface. Limited use can also glaze the brake when surface rust is embedded into the lining. If oily, use brake Kleen spray (off of the tractor) to soak the lining. then let it dry for several hours. If nothing was removed (no discolored oily residue in the spray wash) I would roughen the band and drum with 250 grit silicon carbide paper and put it together. If there is oil, be sure to let the brake Kleen solvent dry completely then use a propane hand torch to heat the lining (off the tractor). do not let it catch completely on fire, just warm and burn sections at a time to boil off the oil/grease. Check the bull pinion shaft seal to assure no oil leaks on to the band. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
